C# 弹出Windows系统内置的软键盘
2025年10月19日 2:9 本文热度 2467
记录弹出软键盘如下:
[DllImport("kernel32.dll", SetLastError = true)]private static extern bool Wow64DisableWow64FsRedirection(ref IntPtr ptr);
[DllImport("kernel32.dll", SetLastError = true)]private static extern bool Wow64RevertWow64FsRedirection(IntPtr ptr);private void TspKeypad_Click(object sender, EventArgs e){    bool isKeyboadRunning = Process.GetProcessesByName("osk").Length > 0;    if (isKeyboadRunning) return;    IntPtr ptr = IntPtr.Zero;    bool redirected = Wow64DisableWow64FsRedirection(ref ptr);    try    {        Process.Start("osk.exe");    }    finally    {        if (redirected)        {            Wow64RevertWow64FsRedirection(ptr);        }    }}
该文章在 2025/10/20 10:22:45 编辑过
