C# 双击鼠标全屏显示或全窗口显示 恢复
2024年12月27日 23:59 本文热度 2459
用控件panel1全屏显示;panel2全窗口显示
通过panel1、panel事件MouseDoubleClick实现。
遮盖panel1上的控件属性的Enabled设置为false,避免捕捉不到双击。
显示界面如下:
代码:
using System.Runtime.InteropServices;
namespace 双击全屏显示或恢复
    public partial class Form1 : Form
        [DllImport("user32.dll", SetLastError = true)]
        static extern IntPtr SetParent(IntPtr hWndChild, IntPtr hWndNewParent);
        static extern IntPtr GetDesktopWindow();
        static extern IntPtr GetParent(IntPtr hWnd);
        static extern int GetSystemMetrics(int nIndex);
        [DllImport("user32.dll", EntryPoint = "ShowWindow", CharSet = CharSet.Auto)]
        public static extern int ShowWindow(IntPtr hwnd, int nCmdShow);
        [DllImport("User32.dll ", EntryPoint = "FindWindow")]
        private static extern IntPtr FindWindow(string lpClassName, string lpWindowName);
        public int SW_HIDE = 0;
        public int SW_RESTORE = 9;
        public bool m_bIsFullScreen = false;//判断是否全屏
        public bool m_bIsFillDock = false;//判断是否全容器
        Rectangle m_RecPanel1 = new Rectangle();//获取原始大小
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            m_RecPanel1 = panel1.Bounds;//获得panel1原始Bounds范围大小
        //控件panel1全屏显示
        private void panel1_MouseDoubleClick(object sender, MouseEventArgs e)
            if (!m_bIsFullScreen)
                //获取桌面窗口并设置为父窗口
                IntPtr hDesk = GetDesktopWindow();
                SetParent(this.panel1.Handle, hDesk);
                int width = GetSystemMetrics(0);
                int height = GetSystemMetrics(1);
                this.panel1.Dock = DockStyle.None;//这个很重要,Anchor属性仍可用
                this.panel1.Bounds = new Rectangle(new Point(0, 0), new Size(width, height));
                ShowWindow(FindWindow("Shell_TrayWnd", null), SW_HIDE);//隐藏Windows任务栏
                //ShowWindow(FindWindow("Button", null), SW_HIDE);
                m_bIsFullScreen = true;
            else
                //获取桌面窗口并设置为父窗口
                SetParent(this.panel1.Handle, this.Handle);
                this.panel1.Bounds = m_RecPanel1;
                ShowWindow(FindWindow("Shell_TrayWnd", null), SW_RESTORE);//Shell_TrayWnd是任务栏的类名
        //全窗口显示
        //也可以用全屏的方法将   panel2.Bounds=窗口的大小;
        private void panel2_MouseDoubleClick(object sender, MouseEventArgs e)
            if (!m_bIsFillDock)
                this.panel2.Parent = this;//以窗口为父控件
                this.panel2.Dock = DockStyle.Fill;//填充至整个父控件大小
                panel2.BringToFront();//可以没有,用来保证panel2在最前面,但是还原时候会遮盖原来在上面的控件
                m_bIsFillDock = true;
            else
                this.panel2.Dock = DockStyle.None;
                //panel2.BringToFront();
源代码下载链接:
https://share.weiyun.com/imRUNgZj
该文章在 2024/12/28 11:57:28 编辑过
