C# 借助NPOI 完成 xls 转换为xlsx,而不安装MICROSOFT OFFICE?
2023年12月30日 0:39 本文热度 3408
背景:MinExcel开类库,导数据的库,占用内存很低,通过io,不通过内存保存,不支持 xls格式的文件,支持csv和xlsx,所以要想使用这个库,就得把xls格式转换为xlsx。只复制了数据 合并单元格,没复制格式这些。
  1. public string ConvertToXlsx(string xlsPath, string newExcelPath)
  2.        {
  3.            VAR oldWorkBook = new HSSFWorkbook(new FileStream(xlsPath, FileMode.OPEn));
  4.            var oldWorkSheet = oldWorkbook.GetSheetAt(0);
  5.            int m = 0;
  6.            try
  7.            {
  8.                using (var fileStream = new FileStream(newExcelPath, FileMode.Create))
  9.                {
  10.                    var newWorkBook = new XSSFWorkbook();
  11.                    var newWorkSheet = newWorkBook.CreateSheet("Sheet1");
  12.                    int i = 0;
  13.                    foreach (HSSFRow oldRow in oldWorkSheet)
  14.                    {
  15.                        var newRow = newWorkSheet.CreateRow(oldRow.RowNum);
  16.                        for (int ii = oldRow.FirstCellNum; ii < oldRow.Cells.Count; ii++)
  17.                        {
  18.                            m = ii;
  19.                            var newCell = newRow.CreateCell(ii);
  20.                            newCell.SetCellValue(GetValueType(oldRow.Cells[ii]).ToString());
  21.                        }
  22.                    }
  23.                    int sheetMergerCount = oldWorkSheet.NumMergedRegions;
  24.                    for (int me = 0; me < sheetMergerCount; me++)
  25.                        newWorkSheet.AddMergedRegion(oldWorkSheet.GetMergedRegion(me));
  26.                    newWorkBook.WrITe(fileStream);
  27.                    newWorkBook.Close();
  28.                }
  29.            }
  30.            catch (Exception ex)
  31.            {
  32.                int b = m;
  33.                throw;
  34.            }
  35.            oldWorkbook.Close();
  36.            return newExcelPath;
网上找的一个更完善的用法,带格式:
  1. using NPOI.SS.UserModel;
  2. using System;
  3. using System.Collections.Generic;
  4. using System.Linq;
  5. using System.Text;
  6. using System.Threading.Tasks;
  7. namespace FixturedataimportFromExcel.COMmon
  8. {
  9.    public static class NPOIExt
  10.    {
  11.        /// <summary>
  12.        /// 跨工作薄Workbook复制工作表Sheet
  13.        /// </summary>
  14.        /// <param name="sSheet">源工作表Sheet</param>
  15.        /// <param name="dWb">目标工作薄Workbook</param>
  16.        /// <param name="dSheetName">目标工作表Sheet名</param>
  17.        /// <param name="clonePRintSETUP">是否复制打印设置</param>
  18.        public static ISheet CrossCloneSheet(this ISheet sSheet, IWorkbook dWb, string dSheetName, bool clonePrintSetup)
  19.        {
  20.            ISheet dSheet;
  21.            dSheetName = string.IsNullOrEmpty(dSheetName) ? sSheet.SheetName : dSheetName;
  22.            dSheetName = (dWb.GetSheet(dSheetName) == null) ? dSheetName : dSheetName + "_拷贝";
  23.            dSheet = dWb.GetSheet(dSheetName) ?? dWb.CreateSheet(dSheetName);
  24.            CopySheet(sSheet, dSheet);
  25.            if (clonePrintSetup)
  26.                ClonePrintSetup(sSheet, dSheet);
  27.            dWb.SetActiveSheet(dWb.GetSheetIndex(dSheet));  //当前Sheet作为下次打开默认Sheet
  28.            return dSheet;
  29.        }
  30.        /// <summary>
  31.        /// 跨工作薄Workbook复制工作表Sheet
  32.        /// </summary>
  33.        /// <param name="sSheet">源工作表Sheet</param>
  34.        /// <param name="dWb">目标工作薄Workbook</param>
  35.        /// <param name="dSheetName">目标工作表Sheet名</param>
  36.        public static ISheet CrossCloneSheet(this ISheet sSheet, IWorkbook dWb, string dSheetName)
  37.        {
  38.            bool clonePrintSetup = true;
  39.            return CrossCloneSheet(sSheet, dWb, dSheetName, clonePrintSetup);
  40.        }
  41.        /// <summary>
  42.        /// 跨工作薄Workbook复制工作表Sheet
  43.        /// </summary>
  44.        /// <param name="sSheet">源工作表Sheet</param>
  45.        /// <param name="dWb">目标工作薄Workbook</param>
  46.        public static ISheet CrossCloneSheet(this ISheet sSheet, IWorkbook dWb)
  47.        {
  48.            string dSheetName = sSheet.SheetName;
  49.            bool clonePrintSetup = true;
  50.            return CrossCloneSheet(sSheet, dWb, dSheetName, clonePrintSetup);
  51.        }
  52.        private static IFont FinDFont(this IWorkbook dWb, IFont font, List<IFont> dFonts)
  53.        {
  54.            //IFont dFont = dWb.FindFont(font.Boldweight, font.Color, (short)font.FontHeight, font.FontName, font.IsItalic, font.IsStrikeout, font.TypeOffset, font.Underline);
  55.            IFont dFont = null;
  56.            foreach (IFont currFont in dFonts)
  57.            {
  58.                //if (currFont.Charset != font.Charset) continue;
  59.                //else
  60.                //if (currFont.Color != font.Color) continue;
  61.                //else
  62.                if (currFont.FontName != font.FontName) continue;
  63.                else if (currFont.FontHeight != font.FontHeight) continue;
  64.                else if (currFont.IsBold != font.IsBold) continue;
  65.                else if (currFont.IsItalic != font.IsItalic) continue;
  66.                else if (currFont.IsStrikeout != font.IsStrikeout) continue;
  67.                else if (currFont.Underline != font.Underline) continue;
  68.                else if (currFont.TypeOffset != font.TypeOffset) continue;
  69.                else { dFont = currFont; break; }
  70.            }
  71.            return dFont;
  72.        }
  73.        private static ICellStyle FindStyle(this IWorkbook dWb, IWorkbook sWb, ICellStyle style, List<ICellStyle> dCellStyles, List<IFont> dFonts)
  74.        {
  75.            ICellStyle dStyle = null;
  76.            foreach (ICellStyle currStyle in dCellStyles)
  77.            {
  78.                if (currStyle.Alignment != style.Alignment) continue;
  79.                else if (currStyle.VerticalAlignment != style.VerticalAlignment) continue;
  80.                else if (currStyle.BorderTop != style.BorderTop) continue;
  81.                else if (currStyle.BorderBottom != style.BorderBottom) continue;
  82.                else if (currStyle.BorderLeft != style.BorderLeft) continue;
  83.                else if (currStyle.BorderRight != style.BorderRight) continue;
  84.                else if (currStyle.TopBorderColor != style.TopBorderColor) continue;
  85.                else if (currStyle.BottomBorderColor != style.BottomBorderColor) continue;
  86.                else if (currStyle.LeftBorderColor != style.LeftBorderColor) continue;
  87.                else if (currStyle.RightBorderColor != style.RightBorderColor) continue;
  88.                //else if (currStyle.BorderDiagonal != style.BorderDiagonal) continue;
  89.                //else if (currStyle.BorderDiagonalColor != style.BorderDiagonalColor) continue;
  90.                //else if (currStyle.BorderDiagonalLineStyle != style.BorderDiagonalLineStyle) continue;
  91.                //else if (currStyle.FillBackgroundColor != style.FillBackgroundColor) continue;
  92.                //else if (currStyle.FillBackgroundColorColor != style.FillBackgroundColorColor) continue;
  93.                //else if (currStyle.FillForegroundColor != style.FillForegroundColor) continue;
  94.                //else if (currStyle.FillForegroundColorColor != style.FillForegroundColorColor) continue;
  95.                //else if (currStyle.FillPattern != style.FillPattern) continue;
  96.                else if (currStyle.Indention != style.Indention) continue;
  97.                else if (currStyle.IsHidden != style.IsHidden) continue;
  98.                else if (currStyle.IsLocked != style.IsLocked) continue;
  99.                else if (currStyle.Rotation != style.Rotation) continue;
  100.                else if (currStyle.ShrinkToFit != style.ShrinkToFit) continue;
  101.                else if (currStyle.WrapText != style.WrapText) continue;
  102.                else if (!currStyle.GetDataFormatString().Equals(style.GetDataFormatString())) continue;
  103.                else
  104.                {
  105.                    IFont sFont = sWb.GetFontAt(style.FontIndex);
  106.                    IFont dFont = dWb.FindFont(sFont, dFonts);
  107.                    if (dFont == null) continue;
  108.                    else
  109.                    {
  110.                        currStyle.SetFont(dFont);
  111.                        dStyle = currStyle;
  112.                        break;
  113.                    }
  114.                }
  115.            }
  116.            return dStyle;
  117.        }
  118.        private static IFont CopyFont(this IFont dFont, IFont sFont, List<IFont> dFonts)
  119.        {
  120.            //dFont.Charset = sFont.Charset;
  121.            //dFont.Color = sFont.Color;
  122.            dFont.FontHeight = sFont.FontHeight;
  123.            dFont.FontName = sFont.FontName;
  124.            dFont.IsBold = sFont.IsBold;
  125.            dFont.IsItalic = sFont.IsItalic;
  126.            dFont.IsStrikeout = sFont.IsStrikeout;
  127.            dFont.Underline = sFont.Underline;
  128.            dFont.TypeOffset = sFont.TypeOffset;
  129.            dFonts.Add(dFont);
  130.            return dFont;
  131.        }
  132.        private static ICellStyle CopyStyle(this ICellStyle dCellStyle, ICellStyle sCellStyle, IWorkbook dWb, IWorkbook sWb, List<ICellStyle> dCellStyles, List<IFont> dFonts)
  133.        {
  134.            ICellStyle currCellStyle = dCellStyle;
  135.            currCellStyle.Alignment = sCellStyle.Alignment;
  136.            currCellStyle.VerticalAlignment = sCellStyle.VerticalAlignment;
  137.            currCellStyle.BorderTop = sCellStyle.BorderTop;
  138.            currCellStyle.BorderBottom = sCellStyle.BorderBottom;
  139.            currCellStyle.BorderLeft = sCellStyle.BorderLeft;
  140.            currCellStyle.BorderRight = sCellStyle.BorderRight;
  141.            currCellStyle.TopBorderColor = sCellStyle.TopBorderColor;
  142.            currCellStyle.LeftBorderColor = sCellStyle.LeftBorderColor;
  143.            currCellStyle.RightBorderColor = sCellStyle.RightBorderColor;
  144.            currCellStyle.BottomBorderColor = sCellStyle.BottomBorderColor;
  145.            //dCellStyle.BorderDiagonal = sCellStyle.BorderDiagonal;
  146.            //dCellStyle.BorderDiagonalColor = sCellStyle.BorderDiagonalColor;
  147.            //dCellStyle.BorderDiagonalLineStyle = sCellStyle.BorderDiagonalLineStyle;
  148.            //dCellStyle.FillBackgroundColor = sCellStyle.FillBackgroundColor;
  149.            dCellStyle.FillForegroundColor = sCellStyle.FillForegroundColor;
  150.            //dCellStyle.FillPattern = sCellStyle.FillPattern;
  151.            currCellStyle.Indention = sCellStyle.Indention;
  152.            currCellStyle.IsHidden = sCellStyle.IsHidden;
  153.            currCellStyle.IsLocked = sCellStyle.IsLocked;
  154.            currCellStyle.Rotation = sCellStyle.Rotation;
  155.            currCellStyle.ShrinkToFit = sCellStyle.ShrinkToFit;
  156.            currCellStyle.WrapText = sCellStyle.WrapText;
  157.            currCellStyle.DataFormat = dWb.CreateDataFormat().GetFormat(sWb.CreateDataFormat().GetFormat(sCellStyle.DataFormat));
  158.            IFont sFont = sCellStyle.GetFont(sWb);
  159.            IFont dFont = dWb.FindFont(sFont, dFonts) ?? dWb.CreateFont().CopyFont(sFont, dFonts);
  160.            currCellStyle.SetFont(dFont);
  161.            dCellStyles.Add(currCellStyle);
  162.            return currCellStyle;
  163.        }
  164.        private static void CopySheet(ISheet sSheet, ISheet dSheet)
  165.        {
  166.            var maxColumnNum = 0;
  167.            List<ICellStyle> dCellStyles = new List<ICellStyle>();
  168.            List<IFont> dFonts = new List<IFont>();
  169.            MergerRegion(sSheet, dSheet);
  170.            for (int i = sSheet.FirstRowNum; i <= sSheet.LastRowNum; i++)
  171.            {
  172.                IRow sRow = sSheet.GetRow(i);
  173.                IRow dRow = dSheet.CreateRow(i);
  174.                if (sRow != null)
  175.                {
  176.                    CopyRow(sRow, dRow, dCellStyles, dFonts);
  177.                    if (sRow.LastCellNum > maxColumnNum)
  178.                        maxColumnNum = sRow.LastCellNum;
  179.                }
  180.            }
  181.            for (int i = 0; i <= maxColumnNum; i++)
  182.                dSheet.SetColumnWidth(i, sSheet.GetColumnWidth(i));
  183.        }
  184.        private static void CopyRow(IRow sRow, IRow dRow, List<ICellStyle> dCellStyles, List<IFont> dFonts)
  185.        {
  186.            dRow.Height = sRow.Height;
  187.            ISheet sSheet = sRow.Sheet;
  188.            ISheet dSheet = dRow.Sheet;
  189.            for (int j = sRow.FirstCellNum; j <= sRow.LastCellNum; j++)
  190.            {
  191.                NPOI.SS.UserModel.ICell sCell = sRow.GetCell(j);
  192.                NPOI.SS.UserModel.ICell dCell = dRow.GetCell(j);
  193.                if (sCell != null)
  194.                {
  195.                    if (dCell == null)
  196.                        dCell = dRow.CreateCell(j);
  197.                    CopyCell(sCell, dCell, dCellStyles, dFonts);
  198.                }
  199.            }
  200.        }
  201.        private static void CopyCell(NPOI.SS.UserModel.ICell sCell, NPOI.SS.UserModel.ICell dCell, List<ICellStyle> dCellStyles, List<IFont> dFonts)
  202.        {
  203.            ICellStyle currCellStyle = dCell.Sheet.Workbook.FindStyle(sCell.Sheet.Workbook, sCell.CellStyle, dCellStyles, dFonts);
  204.            if (currCellStyle == null)
  205.                currCellStyle = dCell.Sheet.Workbook.CreateCellStyle().CopyStyle(sCell.CellStyle, dCell.Sheet.Workbook, sCell.Sheet.Workbook, dCellStyles, dFonts);
  206.            dCell.CellStyle = currCellStyle;
  207.            switch (sCell.CellType)
  208.            {
  209.                case CellType.String:
  210.                    dCell.SetCellValue(sCell.StrinGCEllValue);
  211.                    break;
  212.                case CellType.Numeric:
  213.                    dCell.SetCellValue(sCell.NumericCellValue);
  214.                    break;
  215.                case CellType.Blank:
  216.                    dCell.SetCellType(CellType.Blank);
  217.                    break;
  218.                case CellType.Boolean:
  219.                    dCell.SetCellValue(sCell.BooleanCellValue);
  220.                    break;
  221.                case CellType.Error:
  222.                    dCell.SetCellValue(sCell.ErrorCellValue);
  223.                    break;
  224.                case CellType.Formula:
  225.                    dCell.SetCellFormula(sCell.CellFormula);
  226.                    break;
  227.                default:
  228.                    break;
  229.            }
  230.        }
  231.        private static void MergerRegion(ISheet sSheet, ISheet dSheet)
  232.        {
  233.            int sheetMergerCount = sSheet.NumMergedRegions;
  234.            for (int i = 0; i < sheetMergerCount; i++)
  235.                dSheet.AddMergedRegion(sSheet.GetMergedRegion(i));
  236.        }
  237.        private static void ClonePrintSetup(ISheet sSheet, ISheet dSheet)
  238.        {
  239.            //工作表Sheet页面打印设置
  240.            dSheet.PrintSetup.Copies = 1;                               //打印份数
  241.            dSheet.PrintSetup.PaperSize = sSheet.PrintSetup.PaperSize;  //纸张大小
  242.            dSheet.PrintSetup.Landscape = sSheet.PrintSetup.Landscape;  //纸张方向:默认纵向false(横向true)
  243.            dSheet.PrintSetup.Scale = sSheet.PrintSetup.Scale;          //缩放方式比例
  244.            dSheet.PrintSetup.FitHeight = sSheet.PrintSetup.FitHeight;  //调整方式页高
  245.            dSheet.PrintSetup.FitWidth = sSheet.PrintSetup.FitWidth;    //调整方式页
  246.            dSheet.PrintSetup.FooterMargin = sSheet.PrintSetup.FooterMargin;
  247.            dSheet.PrintSetup.HeaderMargin = sSheet.PrintSetup.HeaderMargin;
  248.            //边距
  249.            dSheet.SetMargin(MarginType.TopMargin, sSheet.GetMargin(MarginType.TopMargin));
  250.            dSheet.SetMargin(MarginType.BottomMargin, sSheet.GetMargin(MarginType.BottomMargin));
  251.            dSheet.SetMargin(MarginType.LeftMargin, sSheet.GetMargin(MarginType.LeftMargin));
  252.            dSheet.SetMargin(MarginType.RightMargin, sSheet.GetMargin(MarginType.RightMargin));
  253.            dSheet.SetMargin(MarginType.HeaderMargin, sSheet.GetMargin(MarginType.HeaderMargin));
  254.            dSheet.SetMargin(MarginType.FooterMargin, sSheet.GetMargin(MarginType.FooterMargin));
  255.            //页眉页脚
  256.            dSheet.Header.Left = sSheet.Header.Left;
  257.            dSheet.Header.center = sSheet.Header.Center;
  258.            dSheet.Header.Right = sSheet.Header.Right;
  259.            dSheet.Footer.Left = sSheet.Footer.Left;
  260.            dSheet.Footer.Center = sSheet.Footer.Center;
  261.            dSheet.Footer.Right = sSheet.Footer.Right;
  262.            //工作表Sheet参数设置
  263.            dSheet.IsPrintGridlines = sSheet.IsPrintGridlines;          //true: 打印整表网格线。不单独设置CellStyle时外框实线内框虚线。 false: 自己设置网格线
  264.            dSheet.FitToPage = sSheet.FitToPage;                        //自适应页面
  265.            dSheet.HorizontallyCenter = sSheet.HorizontallyCenter;      //打印页面为水平居中
  266.            dSheet.VerticallyCenter = sSheet.VerticallyCenter;          //打印页面为垂直居中
  267.            dSheet.RepeatingRows = sSheet.RepeatingRows;                //工作表顶端标题行范围
  268.        }
  269.    }
  270. }
View Code
使用:
  1. using (var fileStream = new FileStream(newExcelPath, FileMode.Create))
  2. {
  3.       var newWorkBook1 = new XSSFWorkbook();
  4.       var sheet = oldWorkSheet.CrossCloneSheet(newWorkBook1, "Sheet1");
  5.       newWorkBook1.Add(sheet);
  6.       newWorkBook1.Write(fileStream);
  7.       newWorkBook1.Close();
  8. }
  9. oldWorkbook.Close();
大部分格式都得行。
这个类的原文地址:C# NPOI Excel 跨工作薄Workbook复制工作表Sheet
该文章在 2023/12/30 0:39:16 编辑过
