站长网拖拽效果完整Js
2011年3月10日 23:33
本文热度 5963
今天在逛站长网时无意中发现站长工具页(http://tool.admin5.com/)各类工具位置支持拖拽,一时兴起研究了下脚本,下边是D下来的脚本(稍做了修改):
[code]
站长网拖拽效果完整Js
<script language="javascript">
var Util = new Object();
Util.getUserAgent = navigator.userAgent;
Util.isGecko = Util.getUserAgent.indexOf("Gecko") != -1;
Util.isOpera = Util.getUserAgent.indexOf("Opera") != -1;
Util.getOffset = function (el, isLeft) {
var retValue = 0;
while (el != null) {
retValue += el["offset" + (isLeft ? "Left" : "Top")];
el = el.offsetParent;
return retValue;
Util.bindFunction = function (el, fucName) {
return function () {
return el[fucName].apply(el, arguments);
Util.re_calcOff = function (el) {
for (var i = 0; i < Util.dragArray.length; i++) {
var ele = Util.dragArray[i];
ele.elm.pagePosLeft = Util.getOffset(ele.elm, true);
ele.elm.pagePosTop = Util.getOffset(ele.elm, false);
var nextSib = el.elm.nextSibling;
while (nextSib) {
nextSib.pagePosTop -= el.elm.offsetHeight;
nextSib = nextSib.nextSibling;
Util.hide = function () {
Util.rootElement.style.display = "none";
Util.show = function () {
Util.rootElement.style.display = "";
ghostElement = null;
getGhostElement = function () {
if (!ghostElement) {
ghostElement = document.createElement("DIV");
ghostElement.className = "toolbox";
ghostElement.backgroundColor = "";
ghostElement.style.border = "2px dashed #aaa";
ghostElement.innerHTML = " ";
return ghostElement;
function draggable(el) {
this._dragStart = start_Drag;
this._drag = when_Drag;
this._dragEnd = end_Drag;
this._afterDrag = after_Drag;
this.isDragging = false;
this.elm = el;
this.header = document.getElementById(el.id + "_h");
this.hasIFrame = this.elm.getElementsByTagName("IFRAME").length > 0;
if (this.header) {
this.header.style.cursor = "move";
Drag.init(this.header, this.elm);
this.elm.onDragStart = Util.bindFunction(this, "_dragStart");
this.elm.onDrag = Util.bindFunction(this, "_drag");
this.elm.onDragEnd = Util.bindFunction(this, "_dragEnd");
function start_Drag() {
Util.re_calcOff(this);
this.origNextSibling = this.elm.nextSibling;
var _ghostElement = getGhostElement();
var offH = this.elm.offsetHeight;
if (Util.isGecko) {
offH -= parseInt(_ghostElement.style.borderTopWidth) * 2;
var offW = this.elm.offsetWidth-4;
var offLeft = Util.getOffset(this.elm, true);
var offTop = Util.getOffset(this.elm, false);
Util.hide();
this.elm.style.width = offW+2 + "px";
_ghostElement.style.height = offH-4 + "px";
this.elm.parentNode.insertBefore(_ghostElement, this.elm.nextSibling);
this.elm.style.position = "absolute";
this.elm.style.zIndex = 100;
this.elm.style.left = offLeft + "px";
this.elm.style.top = offTop + "px";
Util.show();
return false;
function when_Drag(clientX, clientY) {
if (!this.isDragging) {
this.elm.style.filter = "alpha(opacity=70)";
this.elm.style.opacity = 0.7;
this.isDragging = true;
var found = null;
var max_distance = 100000000;
var distance = Math.sqrt(Math.pow(clientX - ele.elm.pagePosLeft, 2) + Math.pow(clientY - ele.elm.pagePosTop, 2));
if (ele == this) {
continue;
if (isNaN(distance)) {
continue;
if (distance < max_distance) {
max_distance = distance;
found = ele;
if (found != null && _ghostElement.nextSibling != found.elm) {
found.elm.parentNode.insertBefore(_ghostElement, found.elm);
if (Util.isOpera) {
document.body.style.display = "none";
document.body.style.display = "";
function end_Drag() {
if (this._afterDrag()) {
return true;
function after_Drag() {
var returnValue = false;
Util.hide();
this.elm.style.position = "";
this.elm.style.width = "";
this.elm.style.zIndex = "";
this.elm.style.filter = "";
this.elm.style.opacity = "";
var ele = getGhostElement();
if (ele.nextSibling != this.origNextSibling) {
ele.parentNode.insertBefore(this.elm, ele.nextSibling);
returnValue = true;
ele.parentNode.removeChild(ele);
Util.show();
if (Util.isOpera) {
return returnValue;
var Drag = {
obj:null,
init:function (elementHeader, element) {
elementHeader.onmousedown = Drag.start;
elementHeader.obj = element;
if (isNaN(parseInt(element.style.left))) {
element.style.left = "0px";
if (isNaN(parseInt(element.style.top))) {
element.style.top = "0px";
element.onDragStart = new Function();
element.onDragEnd = new Function();
element.onDrag = new Function();
start:function (event) {
var element = Drag.obj = this.obj;
event = Drag.fixE(event);
if (event.which != 1) {
return true;
element.onDragStart();
element.lastMouseX = event.clientX;
element.lastMouseY = event.clientY;
document.onmouseup = Drag.end;
document.onmousemove = Drag.drag;
return false;
drag:function (event) {
if (event.which == 0) {
return Drag.end();
var element = Drag.obj;
var _clientX = event.clientY;
var _clientY = event.clientX;
if (element.lastMouseX == _clientY && element.lastMouseY == _clientX) {
return false;
var _lastX = parseInt(element.style.top);
var _lastY = parseInt(element.style.left);
var newX, newY;
newX = _lastY + _clientY - element.lastMouseX;
newY = _lastX + _clientX - element.lastMouseY;
element.style.left = newX + "px";
element.style.top = newY + "px";
element.lastMouseX = _clientY;
element.lastMouseY = _clientX;
element.onDrag(newX, newY);
return false;
end:function (event) {
document.onmousemove = null;
document.onmouseup = null;
var _onDragEndFuc = Drag.obj.onDragEnd();
Drag.obj = null;
return _onDragEndFuc;
fixE:function (ig_) {
if (typeof ig_ == "undefined") {
ig_ = window.event;
if (typeof ig_.layerX == "undefined") {
ig_.layerX = ig_.offsetX;
if (typeof ig_.layerY == "undefined") {
ig_.layerY = ig_.offsetY;
if (typeof ig_.which == "undefined") {
ig_.which = ig_.button;
return ig_;
function $(element) {
var elements = new Array();
if (arguments.length > 1) {
for (var i = 0, elements = [], length = arguments.length; i < length; i++)
elements.push($(arguments[i]));
return elements;
element = document.getElementById(element);
return element;
function chg(elm){
var inner=elm.parentNode.nextSibling;
if(inner.style.display=="block"){
inner.style.display="none";
}else{
inner.style.display="block";
var _Admin5_init = function (el) {
Util.rootElement = el;
Util._rows = Util.rootElement.childNodes;
Util.column = Util._rows;
Util.dragArray = new Array();
var counter = 0;
for (var i = 0; i < Util.column.length; i++) {
var ele = Util.column[i];
for (var j = 0; j < ele.childNodes.length; j++) {
var ele1 = ele.childNodes[j];
if (ele1.tagName == "DIV") {
Util.dragArray[counter] = new draggable(ele1);
counter++;
</script>
<script>_Admin5_init($("page"));</script>
[/code]
该文章在 2011/3/10 23:33:13 编辑过
