sql2005创建存储过程导出数据inset插入语句-如何导出数据
liguoquan
2023年3月29日 16:19 本文热度 3610
:sql2005创建存储过程导出数据inset插入语句-如何导出数据
存储过程代码如下图:
create PROCEDURE [dbo].[Proc_Generateinsert]
@tablename SYSNAME,
@filter NVARCHAR(500),
@Order NVARCHAR(500)
AS
DECLARE @column VARCHAR(MAX)
DECLARE @columndata VARCHAR(MAX)
DECLARE @sql VARCHAR(MAX)
DECLARE @xtype TINYINT
DECLARE @name SYSNAME
DECLARE @objectId INT
DECLARE @objectname SYSNAME
DECLARE @ident INT
SET NOCOUNT ON
SET @objectId = OBJECT_ID(@tablename)
IF @objectId IS NULL -- 判斷對象是否存在
BEGIN
    PRINT 'The object not exists'
    RETURN
END
SET @objectname = RTRIM(OBJECT_NAME(@objectId))
IF @objectname IS NULL
   OR CHARINDEX(@objectname, @tablename) = 0 --此判断不严密
BEGIN
    PRINT 'object not in current database'
    RETURN
END
IF OBJECTPROPERTY(@objectId, 'IsTable') < > 1 -- 判斷對象是否是table
BEGIN
    PRINT 'The object is not table'
    RETURN
END
select @ident = STATUS & 0x80
from   syscolumns
where  id = @objectid
       AND STATUS & 0x80 = 0x80
IF @ident IS NOT NULL
    PRINT 'SET IDENTITY_insert ' + @TableName + ' ON'
DECLARE syscolumns_cursor CURSOR
FOR
    select c.name,
           c.xtype
    from   syscolumns c
    where  c.id = @objectid
    ORDER BY
           c.colid
OPEN syscolumns_cursor
SET @column = ''
SET @columndata = ''
FETCH NEXT from syscolumns_cursor INTO @name,@xtype
WHILE @@fetch_status < > -1
BEGIN
    IF @@fetch_status < > -2
    BEGIN
        IF @xtype NOT IN (189, 34, 35, 99, 98) --timestamp不需处理,image,text,ntext,sql_variant 暂时不处理
        BEGIN
            SET @column = @column + CASE
                                         WHEN LEN(@column) = 0 THEN ''
                                         ELSE ','
                                    END + '[' + RTRIM(@name) +']'
            SET @columndata = @columndata + CASE
                                                 WHEN LEN(@columndata) = 0 THEN
                                                 ELSE ','','','
                                            END
                + CASE
                       WHEN @xtype IN (167, 175) THEN '''''''''+rtrim([' + @name
                            + '])+''''''''' --varchar,char
                       WHEN @xtype IN (231, 239) THEN '''''''''+rtrim([' + @name
                            + '])+''''''''' --nvarchar,nchar
                       WHEN @xtype = 61 THEN '''''''''+convert(char(23),[' +
                            @name + '],121)+''''''''' --datetime
                       WHEN @xtype = 58 THEN '''''''''+convert(char(16),[' +
                            @name + '],120)+''''''''' --smalldatetime
                       WHEN @xtype = 36 THEN '''''''''+convert(char(36),[' +
                            @name + '])+''''''''' --uniqueidentifier
                       ELSE '[' + RTRIM(@name) + ']'
                  END
        END
    END
END
CLOSE syscolumns_cursor
DEALLOCATE syscolumns_cursor
SET @sql = 'set nocount on select ''insert ' + @tablename + '(' + @column +
    ') values(''as ''--'',' + RTRIM(@columndata) + ','')'' from ' + @tablename
IF @filter IS NOT NULL
   AND LEN(RTRIM(@filter)) <> 0
    SET @sql = @sql + ' where ' + @filter
IF @Order IS NOT NULL
   AND LEN(RTRIM(@Order)) <> 0
    SET @sql = @sql + ' Order By ' + @Order
PRINT '--' + @sql
exec (@sql)
    PRINT 'SET IDENTITY_insert ' + @TableName + ' OFF'
创建完后,执行存储过程,要输入三个变量,@tablename是表名,@filter是断点查询条件,接where后的条件,@Order是排序,按哪个字段排序,若全导,设为空即可
代码如下图:
exec Proc_Generateinsert @tablename='scm_bom_list',@filter='',@Order=''
执行完把结果复制出来执行即可
如下图:
该文章在 2023/3/29 16:19:59 编辑过
