C# 异步操作方法的实现
2021年2月4日 16:36 本文热度 6713
C#使用BackgroundWorker执行异步操作的例子,简单的例子,操作开在另一个线程上运行的事件处理和程序,输入线程数,可看到两个线程执行的进度会不一样,运行之后的效果见如图所示。
using System;
using System.Collections;
using System.ComponentModel;
using System.Drawing;
using System.Threading;
using System.Windows.Forms;
namespace ExecuteAsynchronismFunction
    public partial class frmBackgroundWorker : Form
        public frmBackgroundWorker()
            InitializeComponent();
        private int numberToCompute = 0;
        private int highestPercentageReached = 0;
        // 操作开在另一个线程上运行事件处理和序
        private void backgroundWorker1_DoWork(object sender, DoWorkEventArgs e)
            e.Result = ComputeFibonacci((int)e.Argument, this.backgroundWorker1, e);
        private void backgroundWorker1_ProgressChanged(object sender, ProgressChangedEventArgs e)
            this.progressBar1.Value = e.ProgressPercentage;
        private void backgroundWorker1_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
            if (e.Error != null)
                MessageBox.Show(e.Error.Message);
            else if (e.Cancelled)
                resultLabel.Text = "Canceled";
            else
                resultLabel.Text = e.Result.ToString();
            this.numericUpDown1.Enabled = true;
            startAsyncButton.Enabled = true;
            cancelAsyncButton.Enabled = false;
        private void startAsyncButton_Click(object sender, EventArgs e)
            resultLabel.Text = String.Empty;
            this.numericUpDown1.Enabled = false;
            this.startAsyncButton.Enabled = false;
            this.cancelAsyncButton.Enabled = true;
            numberToCompute = (int)numericUpDown1.Value;
            backgroundWorker1.RunWorkerAsync(numberToCompute);
        long ComputeFibonacci(int n, BackgroundWorker worker, DoWorkEventArgs e)
            if ((n < 0) || (n > 91))
                throw new ArgumentException(
                    "value must be >= 0 and <= 91", "n");
            long result = 0;
            if (worker.CancellationPending)
                e.Cancel = true;
            else
                if (n < 2)
                    result = 1;
                else
                    result = ComputeFibonacci(n - 1, worker, e) +
                             ComputeFibonacci(n - 2, worker, e);
                // Report progress as a percentage of the total task.
                int percentComplete =
                    (int)((float)n / (float)numberToCompute * 100);
                if (percentComplete > highestPercentageReached)
                    highestPercentageReached = percentComplete;
                    worker.ReportProgress(percentComplete);
            return result;
        private void cancelAsyncButton_Click(object sender, EventArgs e)
            this.backgroundWorker1.CancelAsync();
        private void frmBackgroundWorker_Load_1(object sender, EventArgs e)
该文章在 2021/2/4 16:36:47 编辑过
