C#:对字符串的各种处理
2021年1月29日 8:36 本文热度 5870
字符串截取
SubString OR Remove
 1  string str3 = "123abc456";
 2
 3  //str3 = str3.Substring(0, i);  //从左边开始取字符串的前i个字符(str3 = str3.Remove(i, str3.Length - i);)
 4  str3 = str3.Substring(0, 3);
 5  str3 = str3.Remove(3, str3.Length - 3);
 6  //输出:"123"
 7
 8  //str3 = str3.Substring(i);     //从左边开始去掉字符串的前i个字符(str3=str3.Remove(0,i);)
 9  str3 = str3.Substring(3);
10  //输出:"abc456"11
12  //str3 = str3.Substring(str3.Length - i);  //从右边开始取i个字符(str3=str3.Remove(0,str3.Length-i))
13  str3 = str3.Substring(str3.Length - 3);
14  //输出:"456"
15
16  //str3 = str3.Substring(0, str3.Length - i); //从右边开始去掉i个字符(str3=str3.Remove(str3.Length-i,i))
17  str3 = str3.Substring(0, str3.Length - 3);
18  //输出:"123abc"
Trim
 1   string str = " I Believe You Very Much! ";
 2   str = str.TrimStart();                                  //截取掉字符串首部的空格
 3   //输出:"I Believe You Very Much! "
 4
 5   str = str.TrimStart('I');                               //截取掉字符串第一个字符
 6   //输出:"Believe You Very Much! "
 7
 8   str = str.TrimStart().TrimStart("Beli".ToCharArray());  //截取掉字符串首部及尾部出现的B或e或l或i字符,删除的过程直到碰到一个既不是B也不是e也不是l也不是i的字符才结束。
 9   //输出:"ve You Very Much! "
10
11   string str1 = " I Believe You Very Much! ";
12   str = str1.Trim();                                      //截取掉字符串首部和尾部的空格
13   //输出:"I Believe You Very Much!"
14
15   //TrimEnd的方法和TrimStart原理一样不多赘述
16   string str2 = " I Believe You Very Much! ";
17   str = str2.TrimEnd();                                   //截取掉字符串首部和尾部的空格
18   //输出:" I Believe You Very Much!"
字符串替换
Replace
1   string str5 = "123abc456efg";
2   str5 = str5.Replace("efg", "EFG");
3   //输出:"123abc456EFG"
字符串分割
Split
1    string str6 = "123,abc,456,efg";
2    string[] str6s = str6.Split(',');
3    foreach (var item in str6s)
4    {
5          ConsoleStr(item);
6    }
7    //输出:"123 abc 789 efg"
字符串连接
Join
1 //结合split里面的字符串数组str6s
2 string str7 = string.Join("-", str6s);
3 //输出:"123-abc-456-efg"
字符串转换大小写
1  string str8 = "abcdefgHIJK";
2  str8 = str8.ToUpper();
3  //输出:"ABCDEFGHIJK"
4
5  str8 = str8.ToLower();
6  //输出:"abcdefghijk"
7
8  bool isUpper = char.IsUpper(str8, 8);
9  //输出:"True"
字符串比较
 1   string str10 = "abackhdk";
 2
 3   string str9 = "abac";
 4   int aa = str9.CompareTo(str10);
 5    //输出:"-1"
 6
 7   string str11 = "b";
 8   int bb = str11.CompareTo(str10);
 9   //输出:"1"
10
11   string str12 = "abackhdk";
12   int cc = str12.CompareTo(str10);
13   //输出:"0"
查找子串
1 str.IndexOf(子串,查找其实位置) ;
2 str.LastIndexOf(子串) ;最后一次出现的位置
3 str.IndexOf("ab",0);
插入子串
1 str.Insert(插入位置,插入子串) ;
2 s.Insert(2,"ab");
移出子串
这里Remove我已经和Substring一起说了。就不细说了
1 str.Remove(其实位置,移出数);
2 s.Remove(3,2);
该文章在 2021/1/29 8:37:03 编辑过
