C#文件下载中文文件名乱码
2018年9月8日 19:1 本文热度 10637
B/S应用中,下载一个附件保存时,中文文件名会乱码,在实际开发中经常遇到,现贴出C#和JAVA的解决方法:
C#:
Response.AppendHeader("Content-Disposition", "attachment;filename=" + Tools.toUtf8String(result));
其中用到的转换方法:
public static string ToUtf8String(String s)
            StringBuilder sb = new StringBuilder();
            for (int i = 0; i < s.Length; i++)
                char c = s[i];
                if (c >= 0 && c <= 255)
                    sb.Append(c);
                else
                    byte[] b;
                    try
                        b = Encoding.UTF8.GetBytes(c.ToString());
                    catch (Exception ex)
                        b = new byte[0];
                    for (int j = 0; j < b.Length; j++)
                        int k = b[j];
                        if (k < 0) k += 256;
                        sb.Append("%" + Convert.ToString(k, 16).ToUpper());
            return sb.ToString();
JAVA:
resp.addHeader("Content-Disposition","attachment;filename=" + Tools.toUtf8String(m_entityIndex.m_sName) + ".xls");
其中用到的转换方法:
public static String toUtf8String(String s) {
        StringBuffer sb = new StringBuffer();
        for (int i=0;i<s.length();i++) {
            char c = s.charAt(i);
            if (c >= 0 && c <= 255) {
                sb.append(c);
            } else {
                byte[] b;
                try {
                 b = new Character(c).toString().getBytes("utf-8");
                    //b = Character.toString(c).getBytes("utf-8");
                } catch (Exception ex) {
                    System.out.println(ex);
                    b = new byte[0];
                for (int j = 0; j < b.length; j++) {
                    int k = b[j];
                    sb.append("%" + Integer.toHexString(k).
                    toUpperCase());
        return sb.toString();
该文章在 2018/9/8 19:01:17 编辑过
